Error on playmaker actions Unity 2018.2
8 years 3 months ago #3185
Replied by Frank on topic Error on playmaker actions Unity 2018.2
Thanks for reporting this issue. It was fixed in 2.8.8a2 (can be downloaded from the beta folder).
I also went and updated the PlayMaker example scene to show better the SetTerm action.
2.8.8a2 have some code to make sure the error doesn't happen even with bad settings, but If you can't update at the moment, there are a couple things you could do to fix the settings and avoid the issue.
First be sure you have PlayMaker and the PlayMaker Unity UI Addon.
Then, open the LocalizationSource in the PlayMaker Localization example scene and in the Spreadsheet/Google tab, change the Update frequency to NEVER.
That will prevent the error from happening.
8 years 3 days ago - 8 years 3 days ago #3283
by sporce
Replied by sporce on topic Error on playmaker actions Unity 2018.2
I'm having a different PlayMaker problem, but also 2018.2(.5):
Assets/I2/Localization PlayMaker/Actions/I2SetCurrentLanguage.cs(10,10): error CS0246: The type or namespace name `I2LocPlayMaker_SelectionMode' could not be found.
This is what I get when upgrading to the latest stable version. The action worked fine beforehand. If I try to manually set the SelectionMode to FsmVariable in the script, it still errors. Any tips?
Last edit: 8 years 3 days ago by sporce.
8 years 3 days ago #3284
Thanks for reporting this issue. With the changes for the new unity prefabs, the PlayMaker actions were not updated correctly.
Tomorrow, I'm going to be uploading to the beta folder a fix for this.
The following user(s) said Thank You: sporce
7 years 11 months ago #3290
by sporce
Sorry, but did you update it yet? I don't see anything new in the Google Drive. I'm not in a rush, though, just wondering in case I misunderstood.
7 years 11 months ago #3293
It is now in the Google Drive:
I2 Localization v2.8.10 a1
7 years 11 months ago #3294
by sporce
OK, thanks! Loaded it into the project and no errors. Appreciated.
